goldenboylate4u
- Apr 19, 2009
- 2
I am in the process of purchasing a 2000- 340 sundancer with twin 7.4 mercruiser engines. mechanic discovered starboard engine with low compression in 1 cylinder. motor was pulled, heads removed and determination was made that valve job was needed. motor had some water in top end. mechanic stated that valve job would correct the problem. could i be in for problems down the road with this? should motor be replaced? engine has 450 hrs on it. thanks
