I received my smart tabs today.
When i opened the package i noticed this little message:
http://www.nauticusinc.com/pdf/SX_cautions.pdf
Obviously, on the smart tabs product description, this message is not shown. Then I started to look for the stainless steel smart tabs. The only difference i can see between the SX model (wich I ordered) and the Stainless model is that the Stainless model uses a steel bolt and SX uses a plastic bolt (wich kinda scares me)
So if I use a steel bolt and locknut instead of the plastic bolt, will it work? (I've sent an email to Iboat to return my product for exchange then i've seen they does not accept any return from canada...
Also, i'm kinda confused on how to install them correctly on my boat.
Here's 2 pictures of the back of a F16.
How can i correctly install the upper part of the trim tabs????
