TampaTrophy
- Apr 18, 2009
- 1
I have a 2004 Mercury 125 (4 cyl) Saltwater Outboard that is due for a new impeller. I was not successful dropping the lower unit to do the water pump job. After removing the 5 nuts (2 on each side under the cavitation plate and one through the anode) the unit would NOT budge. I tapped with a rubber mallet and with a 2X4 and even then it would absolutely NOT move. Is there any other bolt, nut or clamp I overlooked. Everywhere I looked, folks just mention the 5 nuts. Any suggestions?
