I replaced the Coil for the number 1 cylinder and tried starting the motor . had no spark on the number 1 cylinder but had spark on the number 2 cylinder. traced that problem to the white magneto contact on the ignition switch . now
I have spark on the number 1 cylinder but now I lost the spark on the number two cylinder . I traced all wires and they are still connected . I even switched the wires on the coil packs and still no spark but the other pack still works . now I get spark every once in a while but just barely . is there a way to pull the pack apart to see if its just a bad spark plug wire . I know the wire is soldered to the board but can it be replaced?
