Re: Ranger boat trailer
As suggested soak it with PB blaster and let it sit. After it has sat for a while, heat the center of the rim as much as safely possible and heat the hub as LITTLE as possible. The heat on the rim will cause it to expand and then you can whack at it with a hammer carefully to break it loose.
Keep at it, youll get it off.
GL
RC
