Old Evinrude
Papphund
Hi there.
Newbee from Norway here.
I have an old Evinrude, I dont know how old, but I think its 50 HP
But I dont get the electrick gear shift working, And I got no spark on the lower sylinder. Can somebody help me with a wiring diagram to this motor?
The Serial number on this is B625, and model number is 502730.
Sorry for my bad english:rolleyes:
F_R
Re: Old Evinrude
Your English is much better than my Norwegian. Your motor is a 1972 with Hydro-Electric shift. Are you sure it is not shifting? It has to be running before it will shift. Otherwise it will always be in forward gear.
Papphund
Re: Old Evinrude
Hi.
I dont know that, because its wont start:)
But when I crank it, its in forward, and I cant get it in neutral.
On the flywheel it stand "only start in neutral"
How can I get this in neutral?
ezeke
Re: Old Evinrude
Default is forward on your motor. It cannot be shifted into neutral unless it is running.
Papphund
Re: Old Evinrude
On the flywheel it stands "only start in neutral"
So when it starts, then it will go in neutral?
F_R
Re: Old Evinrude
It is shifted by hydraulic pressure from an oil pump in the lower unit. The electric part only operates a couple of oil flow valves. As soon as the motor (and oil pump) start to rotate, it will supply pressure to operate the shift and then it will go into whatever gear the button is pushed for. When it stops rotating, it goes back into forward.
That was supposed to be a safety feature. If anything goes wrong with the system, it goes into forward gear so you can get back home. At least that was the plan.
