imported_Z
- Oct 18, 2006
- 24
I have a 1990 175 hp Johnson on a 20 ft Stratos boat. Steering is getting tighter each year. Disconnected the motor from the cables and the motor moves freely. Indicates the cables and steering unit. This is a dual cable system - Teleflex rack and pinion unit, seems that cables and rack are all one unit . Couple of questions:
Can you replace a dual cable with a single cable? Expect the answer is no - Don't drive the boat in excess of 50 MPH very often. Cost difference is significant.
Can I replace with out pulling the motor off? It seems the latest Teleflex units the cable are removable at the wheel.
Can you cut the old cables to remove them? I was thinking with a sawzall. There is an access point in the back well of the boat that may give me enough clearance to remove the rods.
Thanks for your help. Love this forum, read often to learn about outboards.
Have another post coming shortly on rectifier, tach and charging system. That will wait for another day.
