Re: Thunderbolt IV to Mallory
"Power Timing" :The art of turning the dist. while underway at max rpm to allow the most advance ,allowing the most power with the fuel being used at the time(octane rating). Puts the motor on the "Ragged Edge" of blowing itself apart.Depending on the particular advance weights ,spring rate, how much the holes and stops have been modified ,alters the max advance offered by a MECHANICAL DIST. Electronic ones have a "Hall Effect" device that allows a set degree of advance.TB`s spark or they don`t.
I`d "degree" the cam to make sure you can timing is ok,and verify the timing mark on the damper is TDC #1 .You must remember that marine engines run under "constant load" not like a car.
