This_lil_fishy
Master Chief Petty Officer
- Jul 23, 2008
- 841
Okay, dropped the lower unit in order to change out the impeller (pump kit should be here wednesday). I thought maybe I had a bit of a seal leak as there was a bit of gear oil on the skeg...or I thought maybe it was just unburnt two stroke (here's to good dreams). Well when I dropped the lower unit there was a tonne of goo there (gear oil mixed with water I guess). It appears to have come up around the water pump. I assume there's some seals there that need replacing, but for the life of me I can't get the bottom half of the pump out. Any tips? Do I have to pull the prop shaft to get it out? It doesn't budge at all....I'll break it if I have to...my dealer says I can get the housing cheap...but I don't have the tool to remove the prop shaft...and would prefer not to purchase one.
Also, I noticed that if I pull the vertical drive shaft up, there is a tonne of free play there...but none if I push it down..is this normal? Or should I just break down and rebuild the whole thing.
This is an 86 merc 50 3cyl two stroke. I forget the ser# but that info is correct.
Ian
Ian
