I have an 86 Bayliner Capri 21' OMC 5 Liter engine. Tested the compression today 138 to140 on all cylinders. Also noticed some JP weld on water jacket, I have had boat out and ran it hard without any problems and engine runs at 140 degrees, so I think I am ok with JP weld to the water jacket. When I pulled the plugs all them looked very good except for #4 it appeared to have been exposed to minimal amounts of water, thus my reason for replacing manifolds, boat has never ran hot but manifolds look like they need to be replaced.
I am looking for any guidance in changing out the manifolds and risers? Also, noticed a couple of the bolts on the engine mount are loose will not tighten into stringer, wondering if I can set a bolt into another hole on the steel mount above the stringer, I think they are lag bolts but not sure of the size and length? Any help much appreciated.
Any links or info on manifold replacement would be helpful, what torque to use bolts etc., what gasket sealer etc. Also any links showing how to change out impeller and do drive service. Not finding any information anywhere.
Thanks in advance for any assistance.
