  #1
Old May 13th, 2009, 05:29 PM
totx totx is offline
Default 1994 mariner 60 HP, power trim only work down
Repaired trim motor yesterday, tested ok in the bench.
Tested several times up and down.
Today mounted on the boat, the power trim only working one way, down.
(This was before the piston was connected to the outboard.)
The trim motor is working...
  #2
Old May 13th, 2009, 08:23 PM
CharlieB CharlieB is offline
Default Re: 1994 mariner 60 HP, power trim only work down
If it is a two wire then one of the relays is bad.
The two wire grounds thru the normally closed contacts in the relay that is NOT triggered.
If it runs 'UP' then the NC in the 'Down' relay is good then failsl to run Down it is either failed NC in the in the 'Up' relay OR burnt contacts failing to make a connection when the Down realay contacts its Normally Open (NO) contacts.
  #3
Old May 13th, 2009, 10:31 PM
saumon saumon is offline
An easy way to check if the relay or the pump is bas is to disconnect the 2 wires from the PTT unit at the bullet connectors and connect them directly to a battery. Green on positive and blue on negative should go down and vice versa.
If it works with the direct connections, you'll know something is wrong ahead (trim relay, switch). If it doesn't work, then it's in the PTT unit.
  #4
Old May 14th, 2009, 05:11 AM
Thanks for the answer
The motor is working both ways, but not lifting.
There is a hydraulic problem...
Any known problem, when it works down, but not up?
Like o-ring, valve ore the pump itself. Any drawing available of the pump itself?
It's the two wire type, design one.
http://www.boats.net/parts/search/Me...OW)/parts.html
The pump "base" look like design I, ant the motor look like design II
Last edited by totx : May 14th, 2009 at 05:18 AM. Reason: Changed link to type one design
  #5
Old May 14th, 2009, 10:41 AM
Chris1956 Chris1956 is offline
Ok, Reinstall it on the motor, run the trim motor in the up position and lift the OB with your hands. lock it into the full up position and fill it with Dextron III ATF. let it sit a minute and then cycle it down and then up. You may need to help it. Let is sit for 10 minutes to let the air bubble out and refill and repeat, until all air is gone and the unit is bled.
  #6
Old May 14th, 2009, 11:55 AM
Thanks Chris1956,
It's exactly what i did before I read you reply.
With the filling screw removed, I could tell it was "sucking" air.
Boat on trailer in small hill, hooked of the trailer coupling to level the boat.
Working ok now.
But was surprised, it was working in the bench and not on the boat without load from the OB
Was afraid it was broken ore full of dirt
Changed brushes on the motor and every thing seems ok now...
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1994 mariner 60 HP, change of trim motor totx Mercury & Mariner Outboards 1 May 11th, 2009 06:59 AM
1994 115 Mariner Power Trim and Tilt issue Stripersonthebeach Mercury & Mariner Outboards 3 May 14th, 2008 04:12 PM
60 mariner bigfoot +- 1994 trim and tilt SuperC620 Mercury & Mariner Outboards 3 December 13th, 2007 07:25 AM
More power out of a 1994 60 hp Mercury outboard? Rustybuckets Non-Repair Outboard Discussions 2 July 2nd, 2005 06:14 PM
1994 60 HP Mercury power problems mdeman Mercury & Mariner Outboards 2 May 27th, 2003 10:49 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
