I recently did a compression check after a month w/o one and I found that a cylinder that was at 160 psi was now at 60 psi and the other one dropped from 160 psi to 150psi. This is an old 1980 40hp motor and I am wondering if I do a decarb if this may fix the compression a little? I wanted to try simple stuff before going ahead with a rebuild. Anyone ever have a success stories about a similar situation?
