  #1
Old May 12th, 2009, 01:07 PM
69fastback393 69fastback393 is offline
Default 30hp mariner bogging at high rpm
i have a 30 mariner 79 or 80 model single carb.it had been sitting for awhile. i disassembled the carb and cleaned it,replaced the needle valve,cleaned the nozzle and main jet and every port or orfice i could see,replaced the fuel pump and it cranks and idles fine but when you put it in gear and open the throttle wide open it bogs.i can run it at 1/2 choke and it does fine.
am i missing something that needs to be cleaned? is there a method of soaking the carb.what are you guys suggestions.
  #2
Old May 13th, 2009, 01:52 PM
Default Re: 30hp mariner bogging at high rpm
anybody?
  #3
Old May 13th, 2009, 02:10 PM
solar7647's Avatar
solar7647 solar7647 is offline
I had the same issue with my motor and it ended up being a bad spark plug wire. Just a thought. good luck
__________________
1987 Four Winns 215 Sundowner...
She may be old...but she's got it were it counts!
  #4
Old May 15th, 2009, 02:36 PM
jhawkwx jhawkwx is offline
if your using choke to fuel motor, sounds like a fuel starvation. did you change primer bulb?
What fuel pump did you use to replace yours? I'm having the same problem, but haven't changed my fuel pump yet. I found a mercury/mariner for 70 bucks, but the yamaha version sells for 30 bucks. I'm just curious if anyone knows whether you can interchange the two. Yamaha doesn't show parts beyond 1984, even though I know they manufactured these Mariner badged outboards.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Power Loss / Bogging / No High RPM Range - Need Help!!! 72Glastron75Merc Mercury & Mariner Outboards 7 September 11th, 2008 02:31 PM
Evinrude 50HP bogging when under high RPM Load rebelyel77 Johnson & Evinrude Outboards 2 June 22nd, 2007 09:41 AM
75hp Force Bogging at high RPM plaidpotato Force & Chrysler Outboards 31 June 22nd, 2006 06:35 AM
Force 120 Bogging down at high RPM DoPage Force & Chrysler Outboards 5 May 31st, 2006 05:49 PM
bogging down at high rpm----------help gtholland Non-Repair Outboard Discussions 2 August 22nd, 2001 06:57 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
