I started removing the oil injection system on my '98 Johnson 150 HP Ficht and I disconnected the VRO (oil injection pump), and there were only two wires connected to the pump. I disconnected two wires from the oil tank that were going to the motor. I plugged the oil lines that were going to the pump so any air or dirt would not go to the engine. I mixed a 50:1 fuel to oil ratio, afterward I started the motors and both the oil light and buzzer turned on. My question is, what would I have to do to shut them off and not have them buzz or light on with out having to cut off any wires in the system?
Any help or suggestion are highly appreciated, thank you.
-Jony
-Jony
