  #1
Old May 11th, 2009, 10:15 PM
dannyboy15151515 dannyboy15151515 is offline
Default evinrude 40 lark selectric shift HELP!
HEY GUYS, need some help diehard merk fan. just obtained said motor on 15 ft alum boat mint cond. no fire! what year model? have been reading an learning on here.serial# eo5629 model#40773e guess points --cond-- coils--maybe ignition swith-- help!! where would you start?
  #2
Old May 11th, 2009, 10:59 PM
Joe Reeves's Avatar
Joe Reeves Joe Reeves is offline
Default Re: evinrude 40 lark selectric shift HELP!
Model#40773e is a 1967 40hp Evinrude. Remove flywheel and check for cracked coils. If points are burnt, replace them. Replace condensers with part # 581419.
(Point Setting Of Magneto Models)
(J. Reeves)
Set the points as follows. Have the flywheel key aligned with the fiber rubber portion of the ignition points. Adjust the gap so that a .020 gauge will pass thru but a .022 will not. Should there be any question of the points being dirty (touching the contact with your finger would cause them to be dirty), clean them with a small brush and acetone or lacquer thinner.
NOTE: Should the operating cam have a small portion on it with the word "SET" imprinted, align this portion with the fiber rubbing portion instead of the flywheel key.
Flywheel nut torque is critical.... 105 foot pounds.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
evinrude 40 lark selectric shift HELP! dannyboy15151515 Johnson & Evinrude Outboards 4 September 7th, 2009 02:55 PM
40 hp evinrude lark selectric shift gordon1 Johnson & Evinrude Outboards 5 September 2nd, 2008 10:04 PM
Evinrude 40hp lark vii selectric shift - Timing? Jdialect Johnson & Evinrude Outboards 0 July 29th, 2008 11:26 PM
1966 Evinrude Lark V Selectric Shift Value? ErikF Non-Repair Outboard Discussions 6 June 30th, 2008 02:21 PM
Evinrude Lark 40 Selectric rhhauck Johnson & Evinrude Outboards 1 July 5th, 2002 02:15 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
