  #1
Old May 11th, 2009, 10:05 PM
nebbe nebbe is offline
Default Mercury Ignition wiring
I have a 1983 Mercury electric start outboard. It has been sitting for a couple years and several wires from the ignition system are cracked, corroded, etc. The motor turns over very slowly when both plugs are installed, but with the plugs removed, it turns over strong. I have had it running, and it runs great, but it's been random as to when it starts and runs. It seems to me that the corrosion, etc. are providing too much resistance for the starter and ignition to get enough power. Is there a re-wiring kit available? If not any, recommendations as to the type of wire to use to accomplish this? Thank you.
  #2
Old May 12th, 2009, 12:20 AM
mark_gober mark_gober is offline
Default Re: Mercury Ignition wiring
Nebbe,
Let me tell you how I'd troubleshoot this. Obviously this system runs on 12 volts. Go back to your starter and put a multimeter at the starter 12v connection. Then hit the starter. You should see 12 volts. If you have excessive corrosion on the cable, you will see less voltage there. Another option would be reading the resistance from the starter cable back to the solenoid and then from the solenoid back to the battery. You should read almost zero ohms. Probably less than 2 ohms. A high resistance reading confirms your thoughts.
Mark
P.S. Also, check the connectors right at the battery. Their proximity to the off gasing of the batteries will cause them to corrode much faster than other locations. It's almost always the location of problems.
  #3
Old May 12th, 2009, 11:49 AM
Chris1956 Chris1956 is offline
Nebbe, Also inspect the entire length of the battery cables. A bulge under the insulation indicates corrosion, which will cause high resistance. I had a battery cable that rotted out to only 2 strands. Guess what, my starter turned real slow.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
mercury 6 wire ignition wiring diagram w/ push to choke netminder33 Electrics, Electronics and Trolling Motors 1 June 19th, 2008 02:58 AM
Mercury 40hp Outboard Ignition Wiring diercks1 Mercury & Mariner Outboards 0 July 17th, 2007 06:03 PM
wiring guide for mercury ignition switch 57belair Mercury & Mariner Outboards 4 February 8th, 2007 09:45 PM
Mercury 18 ignition wiring 8ft speeder Mercury & Mariner Outboards 1 June 19th, 2004 05:47 PM
1986 60HP Mercury ignition switch wiring juneaux Mercury & Mariner Outboards 1 April 1st, 2002 08:17 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
