Re: TL Wakeboard Tower
do you mean an LT?.....
i install them......they are a good set up......easy to install....cheap.
the only thing to watch for is when they welded the alum ......some slag blows thru in the tube.......so when you fit the arms in it will catch on the slag and you cannot seperate the arm from the h bar.
you must inspect the peices for the slag befor instlation.....if there is any....it must be removed by a long drum sander on a drill.
other wise the people that have bought the tower say its great.
__________________
IN MEMORY OF Our friend SpinnerBait_Nut LESTER WRIGHT July 31, 1953 - Nov 26, 2008 RIP
