  #1
Old May 11th, 2009, 09:33 PM
farmbrad farmbrad is offline
Default 2000 KW1900CC Kicker Bracket Mounting
Hey, I just became the proud owner of 1900 CC Sportsman & want to add a kicker motor to back up my Yamaha 130. I purchased a NIB Yamaha 15hp 4 stroke (114#s dry). I've built a bracket to hang below the transom rub rail on starboard side. The only accessible location for backup plate & get to locknuts is through the rear storage box. Has anyone any knowledge of this being a suitable setup? Any info appreciated.....
Tim
  #2
Old May 16th, 2009, 10:07 AM
Default Re: 2000 KW1900CC Kicker Bracket Mounting
OK, it's been a few days w/ 0 replies so I'll answer myself:
I drilled the bracket hole pattern going through the storage box for easy access to locknuts. SURPRISE- The transom thickness on bottom bolts is 1-1/4 to 1-1/2 in thick while the top thickness is only 1/2 in. The storage box thickness is 1/8 in! PROBLEM TO BE SOLVED- how to fill void between transom & storage box? SOLUTION= I used solid teflon blocks wedged between transom & box; re-drilled holes through teflon; bolted bracket arrangement on (using plenty of 5200 sealant). This should be solid....I guess water testing this summer will tell the tale! Cheers....
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Mounting a kicker bracket jofish Boat Topics and Questions (not engine topics) 4 April 30th, 2009 06:14 PM
Mounting Garelick Kicker Bracket MikeSpady Boat Topics and Questions (not engine topics) 1 April 23rd, 2009 05:25 PM
Kicker bracket Mounting WIrED Boat Topics and Questions (not engine topics) 2 May 5th, 2004 08:17 AM
mounting my kicker bracket mike_v2v98 Mercury & Mariner Outboards 9 March 30th, 2002 07:57 PM
Help with a mounting bracket for kicker motor?? Jason B Hart Honda & Tohatsu/Nissan Outboards 4 February 23rd, 2001 02:12 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
