Re: 70hp evinrude stalling out
That is also possible. if you have a small gas can, make up some pre-mix in it and take it for a spin. See if it goes away. My boat has a 13g removable tank, so it's pretty easy for me to switch tanks and see what happens. It sounds more like the seafoam and soaking in carb cleaner is working on breaking up whatever it is causing the blockage though, and that's why I'm going with clean and rebuild carbs.
