  #1
Old May 11th, 2009, 11:25 AM
CC Lad CC Lad is offline
Default 20 hp Mariner, pull cable is stuck
Hi folk's, just want to start off by saying A) I'm new to this board and B) what a great forum/source of info this place is.
I have a 20hp Mariner, that worked perfectly all day last Sat. Put it in on Sun, started fine (3rd pull as usual) I backed up a way's to clear the launch, put her into neutral, it then stalled out and would not start.
The pull cord is stuck and will not release as it is engaged. My question is, do I adjust the throttle cable or do I adjust one of the components that adds the tension to the pull cord/fly wheel mechanism?
Any help and or advice would be most appreciated.
Thanks, CC Lad.
  #2
Old May 11th, 2009, 01:28 PM
mark_gober mark_gober is offline
Default Re: 20 hp Mariner, pull cable is stuck
CCLAD,
Is your motor a tiller motor? On mine, when it's in gear and at a little more than idle, an arm swings around to prevent you from starting the motor. This is a safety measure to prevent you from accidently starting the motor at full throttle while you are standing up. (thats my guess anyway) You should verify that you aren't in gear. Did your rope retract? I'm taking from what you said that the rope won't pull out. Is that true? If you are in neutral and it still won't pull, you might remove the cowl and see if the pull rope will pull with it removed from the engine. If it will, you know the problem is the engine. If not, it's not hard to figure out the pull start mechanism. Usually if they fail though, the rope breaks or it won't engage. If it was permanantly engaged, it would make a clicking sound with the engine started. Let me know how it turns out.
Mark
P.S. What kind of motor is it? Year/2 or 4 stroke/Electric or manual start etc.
  #3
Old May 11th, 2009, 07:05 PM
Thank for the reply Mark. It is a 1989 2 stroke Mariner - Tiller. Yes the catch that prevents starting when above an idol is engaged. I think the throttle cable needs to be tighter in order to un engage it. I see how the system works, - How do you adjust the throttle cable?? If I pull it by hand the catch disengages.....
Again thyank you for the reply Mark.
Tim.
  #4
Old May 13th, 2009, 08:30 PM
When you switch from forward to reverse, is there anytime that the lever disengages from the flywheel? If so, and it just does so at the wrong time, you are right, it just needs to be adjusted. On my motor, the tiller handle has two wires that go to a cam. Rotate one way and one way pulls, rotate the other, it pulls back the other direction. Right where those cables meets the cam, there should be a nut on the cable that attaches it to the motor. You'll need to adjust that nut to adjust the cable. If the latch is always engaged, no matter what, you need to address that.
Mark
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Mariner 1993 20 HP Tiller to Cable steering ? Risto Mercury & Mariner Outboards 0 April 16th, 2008 10:23 AM
Mariner 8 HP, pull start won't pull. locked up maybe? jrod15 Mercury & Mariner Outboards 0 July 3rd, 2007 06:09 PM
20 hp motor lower unit stuck spacecwboy Mercury & Mariner Outboards 10 May 16th, 2006 06:19 AM
evinrude 1985 20 hp pull start jimmymarshall Johnson & Evinrude Outboards 1 July 25th, 2003 09:09 AM
96 Merc. 20 Jet pull start stuck..?? speckren Mercury & Mariner Outboards 0 June 7th, 2003 04:37 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
