JTMatthews
- Nov 6, 2008
- 6
Okay, so last time i took the boat out, my whole shot was great but once i got to top speed i was at top speed for about 5-10 seconds and then the motor just suddenly bogged down I have checked my hoses and just replaced my fuel line and primer bulb and installed an inline fuel filter after the problem started and that didn't fix it, could my fuel pump possibly be going out? I had a mechanic listen to it and he thinks maybe i either got a bad batch of gas or i could be getting air in somewhere but I can't find any leaks and am starting to lean the fuel pump. when the motor would bog down, if i put the motor back into neutral and then throttle back up, it is just like before good whole shot plane out and then top speed and them bam bog down... and as long as i don't go completely full throttle it doesn't happen...
Anyone have any other ideas i can troubleshoot with?
