Carburetor Problems?
Frank H
I purchased a 95 Sea Ray last year with a Mercruiser I/O motor. It suddenly stopped running and when I would restart it, it would idle very low. When I attempted to give it gas, it would stall out. I took apart the carburetor and found it clogged with gunk. Put everything back together, was running great when the same thing happened again. This time I cleaned and rebuilt the carburetor and removed the gas tank and cleaned it out (where I thougt I found the source). Had it out this weekend, everything was running great for about two hours when the problems started over again. Any suggestions for diagnosing the problems?
Thanks
cooter2506
Re: Carburetor Problems?
DId you change to water seperator filter and clean the carb filter? Did you soak carb over nite and then blow out with compressed air? Did you use a rebuild kit or usee old gaskets?
