1986 mercury 50 hp
downeaster06
My 1986 mercury 50 hp 2-stroke has just had both carbs professionally rebuilt and tuned, stator replaced, plugs and wires replaced, all fuel lines replaced, fuel filter replaced. I recently took it out for a test run and she ran great for about 15 to 20 mins. Then i went over a wake from another boat as it passed and my outboard suddenly lost over half its power and speed and wont open up any more, any suggestions? also compression is good and water pump and temp has been professionally checked too.
Laddies
Banned
Re: 1986 mercury 50 hp
It sounds like who ever cleaned the carbs did half a job and did not clean the tank, so when you hit the wake it shook crude in the tank up and the fuel pump sucked it up and pumped it into the carbs so your back to square one.
downeaster06
wow gosh that could be.. I hope not but i'll def. check the tank for any contaminates, and thanks for the help! lets say if it's not that any other suggestions? maybe a bad coil pack, power pack? something electrical?
