  #1
Old May 11th, 2009, 01:58 AM
wvmedic's Avatar
wvmedic wvmedic is offline
Send a message via MSN to wvmedic
Default 1984 Yamaha 90 HP alarm going off?
I have a 1984 90 hp Yamaha and was out on the lake today trying it out after rebuilding the carbs.
We idled threw the no wake zone and I throttled up to WOT the boat hadn’t gotten up on plane yet and the alarm started, had to back off on the throttle to near an idle and the alarm went off in a short while. When I would try to power up again the same thing would happen.
There was a steady stream of water from the tell tale, water was warm but there is a thermostat on the motor so I am taking this as normal. The cylinder head was hotter than I would have expected but not so hot that I couldn’t touch it, but I wouldn’t want to hold my hand on it for long.
Also after rebuilding the carbs I bled the oil pump and disconnected the oil supply line on the top carb, no oil from the line. I didn’t move the rod going to the pump as the manual said to but I would still expect some oil from the line at idle.
As a precaution I did pre mix at 50:1.
Any Ideas as to what the problem is likely to be?
Jeff.
  #2
Old May 11th, 2009, 09:58 PM
wvmedic's Avatar
Default Re: 1984 Yamaha 90 HP alarm going off?
I suspect the impeller but was woundering what the rest of you think.
Jeff.
  #3
Old May 12th, 2009, 10:04 AM
capt sam capt sam is offline
impeller, stuck poppit valve maybe, when you pull the poppit and thermostat check the head for salt blockage too.
__________________
Love the life you live, live the life you love-Bob Marley
  #4
Old May 12th, 2009, 05:11 PM
wvmedic's Avatar
capt sam, please forgive my ignorance but what is a poppit valve?
I have a good bit of automotive experience, but very limited marine experience.
Also I should have mentioned that this motor has been fresh water only motor.
Thanks Jeff.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1984 Chrysler 90 HP Brandenton Force & Chrysler Outboards 5 March 21st, 2009 09:13 AM
90 hp Yamaha alarm wire color? surfbass Yamaha & Suzuki Outboards 6 March 1st, 2009 01:53 PM
temp indicator and alarm yamaha 90 help! ken privette Yamaha & Suzuki Outboards 2 March 7th, 2008 11:00 AM
1984 yamaha 115 alarm? greggg Yamaha & Suzuki Outboards 11 September 5th, 2006 06:56 PM
1984 90 HP Johnson Pods Johnson & Evinrude Outboards 1 February 28th, 2005 08:07 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
