Re: 1991 60hp johnson shuts off after putting in gear
check your compression and spark on all 3 cylinders. also carbs can pick up trash anytime and cause problems. have you replace your fuel lines with alcohol resistant lines? ethanol, deteriorates the rubber lines, and the lines sluff out, clogging high speed jets.
see carb cleaning in TOP SECRET FILE.
