Re: Changing water pump on 40hp mercury 402
I just did the same job The impellar will only turn one way
my water preasure was low because the water jacket gasket sprung a leak
which I am now trying to fix
cannot seem to find a replacement part so i gooped it up (cross fingers)
My gear linkage is still out I had neutral and reverse now I only have forward will try again later to line it up
should be easy put linkage in Neutral put shifter in netraql and re-install but did not work oh well
