Kentucky Mark
- Apr 12, 2009
- 1
First of all Hello. I find this a well attended sight with endless knowledge!!!
I have a 91 200 hp EFI. My father owned this motor/boat and upon his passing I have received it. It did sit for 3 years and after I drained all the old gas and replaced the lower unit lube and plugs i went on a test run. The beeper started screaming and i found the 2 cycle oil everywhere.
Further investigation indicated the oil lines from the resevoir on top of the engine were broke where they fed into the engine. I replaced 2 different lines and tried again. still beeping. I then added oil to the resevior unit on top of the motor and all was well for a 15 minute run.
Next weekend used for one day all was well till it heated up and water pressure droped to almost 0 while idling. I had a new impeller installed.
Today took off. water psi was 15 lbs and temp reading was between 1/4 and 1/2 half. bu tthe beeper went off.
As the very first I ran it the top resevoir was low enough that the float indicated a problem. I topped of hoping that it would prime itself once full but no go 1/2 later it beeped and was low again. Then again 1/2 later. As long as I manually add to the resevoir on the motor all is well till it uses oil dropping the float to warning level.
Do I need to somehow prime the top resevoir from the main in the boat.?
The previous weekend it did pull from the main as I used it for the better part of a day and it used 1/4 tank. Is oil that is 3 years old bad and clogging a filter.
Any advice?
Thanks!
Any advice?
Thanks!
