engine idle
cger
hi, i have a 1991 mercruiser ,5.7, just wondering when i am starting i have to open throttle 3/4 to get it to start, also until fully warm it does not want to idle, will idle for a minute and then revs get lower and lower until it stalls
is this normal? thanks ger....
Re: engine idle
Ayuh,... Carbed motors require abit of babysitting, unlike EFI motors...
Don S
Re: engine idle
Sounds about normal for a carbed engine, they don't act like your cars EFI engine.
A tuneup, carb adjustment, and having the choke adjusted properly will minimize the problem, but pumping the throttle once or twice on a cold engine and keeping the rpms up around 900 to 1200 rpm is fairly typical.
cger
Re: engine idle
good to know thats norhing much is wrong, will get it tuned up, thanks for answers. ger....
cger
Re: engine idle
have another question for you guys, my motor for tilting up and down outdrive is not working, i can hear motor clicking, but nothing happens, any ideas, i am only new to this boats, boat is bayliner 2655 year 1991,
thanks ger.....
Don S
Re: engine idle
Do you have an Alpha I or Alpha I Gen II outdrive. 1991 might be the boat year, but it may not be the year of the engine and drive.
bigbob_FTW
Re: engine idle
thanks ger.....
Mine had become rusted inside. took it apart and cleaned it up, and it was good as new.
cger
Re: engine idle
was told it is Alpha I Gen II outdrive,
Don S
Re: engine idle
Go up to the Adults only sticky at the top of this forum and go to the servce manual links. Download manual #14. Then go to section 1C for detailed troublshooting of the trim system with wiring diagrams.
