  #1
Old May 9th, 2009, 05:58 PM
kawaboy-zx11 kawaboy-zx11 is offline
Default 76 25hp evinrude not pumping water!
i need help... i bought a 1976 25 hp evinrude and it wasnt pumping much water out the exaust hole and it would get hot quickly. so i ordered a new impeller and put it in today and still the same problem...hardley any water coming out, and the head gets to hot to touch in just a few seconds of running in the barrel, i looked to see if a baggy got sucked in or something and there is nothing clogging it. i see when you order the impeller "kit" it comes with the metal plate. could that be the problem? the metal plate is worn? Thanks, Dennis
  #2
Old May 9th, 2009, 06:24 PM
bankerjohn's Avatar
bankerjohn bankerjohn is online now
Default Re: 76 25hp evinrude not pumping water!
On a motor that old, I would have opted for a complete water pump kit instead of just the impeller. But I doubt a worn plate would cause the motor to overheat as quickly as yours apparently did.
Your motor also has a thermostat ... I'd strongly suggest replacing it with a new one ... but be careful removing the the 3 bolts that hold the thermostat cover on ... it's really easy to shear one off on an old motor!
A couple other thoughts ... are you sure you put the impeller pin back in? ... and the water tube, was there a grommet or o-ring at the top of the exhaust housing that it fits in? If so, was it properly seated? How about the grommet in the water pump housing?
__________________
1996 Evinrude 9.9 4-stroke
1995 Yamaha 115 2-stroke
Last edited by bankerjohn : May 9th, 2009 at 06:36 PM. Reason: Added another thought
  #3
Old May 9th, 2009, 08:23 PM
i replaced the water line grommet today, didnt help, the pin is in the impeller, i removed the thermistat, made no difference. i just removed the powerhead, looks like i need a new gasket in there too (when i ran water up the waterline it was comming out the powerhead). i still dont think ive found the problem.
  #4
Old May 12th, 2009, 10:47 PM
well just incase anybody was wondering...it was the impeller plate causing it not to pump. i replaced it with a new one and it pumps like a son of a gun! Thanks, Dennis
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
No water pumping...1957 Evinrude 18hp Fastwin 1957Evin Johnson & Evinrude Outboards 3 March 19th, 2009 11:34 AM
Evinrude 150 Not Pumping Water DANNYMC24 Johnson & Evinrude Outboards 4 March 22nd, 2008 03:39 PM
Evinrude 25rcos not pumping water Keith Haw Johnson & Evinrude Outboards 2 July 23rd, 2007 04:19 PM
1993 evinrude 4hp not pumping water ohmybad Johnson & Evinrude Outboards 3 September 4th, 2006 12:15 PM
Evinrude not pumping water right???? reddog349 Johnson & Evinrude Outboards 47 November 17th, 2005 03:31 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
