OY..
I have a 1985 mercruise 170 i/o. and am attempting to remove the starter motor to replace it (I believe the field is weak). Any how.. It is the delco type with two 5/8" nylon mounting nuts on studs. I can barely get to the lower nut with a wrench and believe I can tease that one off. The top nut however is another story. I can't figure out a decent way to get that nut off the stud. I have removed and pulled the water pickup hose out of the crevase to try to make room but I can't get anything on the nut. The starter housing is too close to the side of the nut to get a wrench on it and there isn't enough axial distance to get a socket in there. The only thing I can see right now that may help is to remove the closed cooling hose that comes wraps around the block there. I could really use some guidance if there is any way to get around draining the closed cooling system and removing the hose to get some working room. The space around the side of the nut is probably only wide enough for a socket. (It has a 5/8" nut, not a 1/2" that other people seem to have.) I cant get my craftsman ratcheting wrench around it. Any ideas?
TIA.
TIA.
