  #1
Old May 9th, 2009, 04:42 PM
relo relo is offline
Default Mariner 100 Remote Control Jammed
Howdy. Took my '89 Sea Ray out for the first time this season. I stopped in the middle of the lake to check the live well, etc. When I went to put the engine back in gear, the control lever jammed. Until then, the throttle and shifter had been working normally. After a few seconds fiddling with the control, the throttle locked wide open. I paddle back to shore. I have the manual for the Mariner 100 but it has nothing about the remote controls. Where should I begin? I haven't done anything yet except get the boat out of the water. Any suggestions or sources of info would be greatly appreciated.
This is a Morse control. The only markings in can find are INOOM under the Morse name.
__________________
It's never too late to have a happy childhood!
  #2
Old May 9th, 2009, 10:39 PM
CharlieB CharlieB is offline
Default Re: Mariner 100 Remote Control Jammed
First thing I'd try is to disconnect both cables at the motor and try the control again to see if it is the control or a cable sticking.
Often a worn cable digs/cuts/wears a groove inside the cable housing, sort of 'pinching' the cable when placed under load. Disconnected, the cable moves freely.
If the control moves freely with the cables disconnected, then connect only one cable and try it again, if a cable is bad your control will stiffen once the bad cable is reconnected.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
tiller control and shifter mech jammed bigshu22 Mercury & Mariner Outboards 0 August 9th, 2008 11:39 AM
I need help 94 Mariner covert tiller to remote control! bore123 Mercury & Mariner Outboards 0 May 25th, 2008 12:24 PM
remote control MASTER Brian Johnson & Evinrude Outboards 4 September 5th, 2006 01:56 PM
Conversion of Mariner 40 from Tiller to Remote control jasper2447 Mercury & Mariner Outboards 0 August 17th, 2004 08:30 AM
remote control 97 mariner ML 25 alone Mercury & Mariner Outboards 2 April 15th, 2004 07:56 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
