Glassport from Newport
- Mar 31, 2009
- 32
When I pulled my outdrive, I had some water in the u joint bellows area. Not much, maybe 4 ounces. Is this ever normal?
I just had the bellows replaced last summer.
There is no water in my outdrive oil (or lube whichever you prefer).
I have had no water comming into my boat in that area all last running season.
I did have an issue this winter with my boat cover leaking and I had a small piece of debri clogging my boat's drain plug hole. So consequently I had some standing water in the rear of the boat for a good week or two. I am not sure if it was enough water to reach the drive shaft area.
