  #1
Old May 8th, 2009, 11:26 PM
Nymmrod1 Nymmrod1 is offline
Angry 1994 150 evinrude shake at 3000 RPM. Please help
at 3000 rpms left motor stars to shake and will not go over 3100 rps I checked the prop and drained all the carbs to no avail?? any ideas
  #2
Old May 9th, 2009, 01:14 AM
jonesg jonesg is offline
Default Re: 1994 150 evinrude shake at 3000 RPM. Please help
"at 3000 rpms left motor stars to shake "
what exactly does that mean, you have twin engines and the left one shakes?
Sounds like its going into SLOW rpm limit, it should run at an rpm limit of 2500 but if its a twin the good un is dragging it along.
When you turn the ignition on does the ignition give a test beep.?
You should be getting an alarm too if this is whats happening, unplug the wire from the heat sensor and ground it to the block, buzzer should sound.
Key on.
  #3
Old May 9th, 2009, 01:25 AM
MarcG007 MarcG007 is offline
Plugs possibly could be fowled. Faulty coil, bad wire maybe? whens the last time plugs at least where replaced?
Does it start easily?
Marc
  #4
Old May 9th, 2009, 06:19 AM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
start with the basics, compression check, spark check. when were the carbs last cleaned and rebuilt? could be clogged high speed jets. do both motors run off the same tank?
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #5
Old May 9th, 2009, 07:52 AM
Yes there are twins . It starts and runs fine but when I get to 3000RPMs it starts to shake like it has a bad miss they both run off the same tank ??
  #6
Old May 9th, 2009, 08:15 AM
Default 1994 150 evinrude shakes at 3000 rpms
There are twins and both run off the same tank plugs look good but I am going to change?? How to check the coil?? and I have no alarm sounding ?? carbs were leaking but I removed and torked now no more leaks but I didn't blow air through any jets?? should I take off and clean the jets??
  #7
Old May 9th, 2009, 09:33 AM
Default 1994 150 shake at 3000 RPMs
Just did a comp check 110 on all cylinders plugs are dark and some build up?? Help!!
  #8
Old May 9th, 2009, 09:40 AM
Default Re: 1994 150 shake at 3000 RPMs
use only this thead, all others have been merged to it.
take an induction timing light with you. check your spark on every cylinder, when it is shaking.
__________________
FLORIDA GATORS
TEBOW Country
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1994 150 evinrude shake at 3000 RPM. Please help Nymmrod1 Johnson & Evinrude Outboards 4 May 9th, 2009 07:52 AM
1994 Johnson 150 Ocean pro low range rpms rough deviljohn Johnson & Evinrude Outboards 1 September 1st, 2008 09:53 AM
1994 115 missing and alarm going off not reaching 5200 rpms only 4400 rpms 1531665anthony Mercury & Mariner Outboards 1 September 25th, 2007 07:43 PM
1994 115 mercury missing and alarm going off not reaching 5200 rpms only 4400 rpms 1531665anthony Mercury & Mariner Outboards 1 September 23rd, 2007 10:22 AM
won't exceed 3000 RPMs Trophy owner 1234 Mercury & Mariner Outboards 7 August 9th, 2005 08:14 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
