I have 1990 Chaparrel 1800 with 3.0 mercruiser.
Engine was rebuild or maybe even swapped by previous owner, thats what my mechanic told me. Still has electronic distributor in it, but for some reason runs on the old distributor system.
Bot runs fine, nice a strong.
I wanted to do spring tuneup, distributor cap, rotor, points, spark plugs wires...
Here is the problem I got:
I went and got new distributor cap and rotor that is inside distributor, but after looking at it, the distance between the rotor and points on the distributor is more then on the old one. I got my digital caliper out ,and here is what I got
Old distributor distance between rotor and points on distributor is 2mm, and on the new one is 4mm
I went back to my local boat shop where I do all my stuff, and they checked and part # are all good, my mechanic says that there should be a space, between, and thats fine.
Is this about right what they telling me?
Seems like little to much of the spacing
thanks
thanks
