Re: 2000 60hp. Yamaha impeller change
i think the lower unit will just separate once you remove the bolts. there is a bolt underneath the trib tab zinc, so you have to remove the zinc and then the bolt underneath.
the gear linkage will slide off a collar when you separate. when putting it back together, on that last inch, line up the linkage and slide together.
