  #1
Old May 8th, 2009, 05:39 PM
a70eliminator a70eliminator is offline
Default 67 evinrude 80hp speedifour carb linkage
I dropped my motor trying to lift it onto the transom, it broke the link pin off the distributor to carb linkage. I made a new pin and it's all back together now.
I see three adjustments:
#1 slotted holes on the flat arm
#2 threaded length adjustment carb end
#3 distributor stop screw
Anyone care to give me a quick run down on what to look for in a preliminary baseline check.
The roller that rides on the big cam that operates the throttle plates just barely looses contact at throttle off (plates completely closed)
The roller rides up the cam as throttle is applied, then drops into a valley , a sorta dead zone where nothing is happening, other than the distributor is advancing, the cam then comes up out of the valley and begins to advance the throttle plates again at which point the distributor is just advancing past the start position arrow and eventually bottoms on the fixed bumper stop, (full advance) am I missing anything I should be looking at? I realy should get a manual but I'm just tinkering around getting ready for the first sea trial after a motor swap.
  #2
Old May 8th, 2009, 09:19 PM
F_R F_R is offline
Default Re: 67 evinrude 80hp speedifour carb linkage
You could get a manual a lot easier than I can sit here and type it all out for you. However, short story is the throttle plates just start to crack open when the roller is centered on the mark on he cam.
See the vertical shaft that operates the throttle? If you look straight down on it from above, you will see a flat edge on the bracket that holds it. The distributor should hit the full advance stop as the control arm lever aligns with that edge. Then further movement of the control lever kicks the carburetor wide open.
Disclaimer: This is from memory. I don't have the 1967 book either. Parts vary by year. Besides, the manual has pictures.
  #3
Old May 8th, 2009, 10:41 PM
Thanks! I will look for that too. I'm thinking the settings should be pretty good as it looks to have not been messed with very much and I marked all the settings before removing and cleaning it all up, but tomorrow's the acid test. I'll post the results.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
prop ? for a 67 80hp evinrude drrtydog Prop Questions and Topics 2 June 26th, 2009 09:43 PM
Carburetor distributor linkage 67 evin 80hp a70eliminator Non-Repair Outboard Discussions 0 May 7th, 2009 07:14 PM
67 80hp evinrude couple ?'s drrtydog Johnson & Evinrude Outboards 3 August 22nd, 2007 08:19 AM
'67 80hp Evinrude... No Spark stone Johnson & Evinrude Outboards 1 June 22nd, 2007 05:54 PM
need a prop for my '67, 80hp evinrude ole Johnson & Evinrude Outboards 3 May 7th, 2002 08:46 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
