Nandy
- Apr 10, 2004
- 2,145
I have a prop that does not have any markins on it. Believe me. I have looked everywhere and have let other people familiar with boating look at it and no cigar...
I do have another prop and they look very similar... except for the paint and minor design differences. The prop place is a long 3 hours + round trip and I dont want to do the trip unless is absolutely necessary.
I was thinking I could use the prop with the known pitch number to find out if it is the same as the unknown one. I can apply some expanding foam to the face or back side of the blade all the way until it gets to the body of the prop (will use some sort of release agent), pull that cast away and use it to measure the other prop. I will think that if the blade and body of the unknown prop fits that mold then both props are the same pitch... Will that be true? or Should i just cut the mold at the point that it touches the prop body and use that as a template? Would this work at all? I think that is similar to the process that the prop shop will use to find the pitch...
The 2 props do look the same to me and I dont recall any change in speed when I changed them. I dont know about the RPM since I dont have one installed (bought it, just working in the installation now). The known prop is 13 1/4 x 17, should a 13 1/4 x 19 or 13 1/4 x 15 be easy to distinguish from a 13 1/4 x 17?
Thanks!!!
Thanks!!!
