dsmskyline
- Mar 1, 2009
- 3
I just boat this boat about a month ago. Paid a large sum of $100 for it and a good trailer.
It is an open bow, outboard motored boat.
I figured it will be a good project boat, the hull is in good shape with a little beach rash. The interior needs redone as it sat outside with no cover.
Im at the point that I know I will need to replace the transom and the stringers/foam.
Ive been looking around at some posts here in the restoration section and found a couple projects that were done on tri-hull boats.
I was wondering if most or all tri hull boats have stringers that run bow to stern?
Has anyone done any stringer replacement on this type of boat that could give some input?
I gave thought about doing a stringer less rebuild and just using 4lb foam. I will probably add a couple floor supports or maybe even a full center stringer.
I havent started to tear anything apart yet as I want to make sure it is going to be worth all the work.
Thanks for the space,
Thomas
Thomas
