farscapehw
- Mar 17, 2009
- 12
i got my mercury 200 20hp running, (thanks for the help with the electrical stuff. it was a short in the orange wire to ground for the ignition switch up front of the boat)
now my impaler isnt even trickling water. so i took the nut on the front of the lower unit loose and the nut above the prop off and the front of the unit is loose but the rear near the prop is not coming loose. is there another bolt?
there is an aluminum plate with no bolts in it above the prop and above that from the top there is a tiny round hole i see another bolt in but cant get a socket on.
anyone have the procedures for changing the water pump?
serial # 4148481
serial # 4148481
