  #1
Old May 8th, 2009, 10:47 AM
agderek agderek is offline
Default 1983 Evinrude 15hp turns but won't crank
Hello all,
I have an older model Evinrude 15hp with pull and electric start that I received from a cousin. It had sat up for a while but we did get it to idle prior to starting any maintenence. Here is what has been done: New plugs, new gas mix, compression checked and okay, new impeller installed, carb cleaned, new battery.
Here is the deal: We have good spark at the plugs and the engine does not flood when trying to crank BUT I cannot get it to crank. The starter turns it over fine but it doesn't catch to idle. It acts like it is not getting fuel. I have a new fuel line and primer bulb. However, I have a very old metal gas tank. Could this be my problem? When I disconnect the fuel line from the motor and push in the outlet no fuel comes out until I squeeze the primer bulb... should fuel already come out if the primer bulb is already primed?
I put the fuel line on backwards once and obviously it wouldnt crank (it seems like that is what is happening now BUT the fuel line is on correct)
Thoughts???
ds
  #2
Old May 8th, 2009, 12:48 PM
Rick. Rick. is offline
Default Re: 1983 Evinrude 15hp turns but won't crank
After you've cranked it you should check the plugs to see if they are getting gas to them. If they are dry do a carb. cleaning c/w a new kit. If your bulb gets firm, it is moving gas, if it doesn't get firm it may have a bad check valve in the bulb. The little ball in the connector is a check valve which is displaced when you connect it to the gas fitting on your motor so by design you can't get gas flow through the hose unless you move the ball out of place. The other thing to try is spraying a gas oil mix directly into the carb. when cranking. If the motor starts and runs you'll know you have a fuel problem. You say you cleaned the carb. so I would assume you set the needle valve to it's proper place for initial start? Look at the top item on this forum, Top Secret File for information about your initial carb. setting. Last thing is to have a look at this article as I believe it is a must read for any OMC 9.9 or 15 owner. Best of luck. Rick.
http://www.sschapterpsa.com/rambling...OMC%20info.htm
  #3
Old May 8th, 2009, 02:41 PM
Thanks Rick. Now I know what the Top Secret File is all about.
Question: Regarding spraying gas/oil mix directly into carb when cranking, should I just use a small squirt bottle?
  #4
Old May 8th, 2009, 03:12 PM
wbeaton's Avatar
wbeaton wbeaton is offline
That's what I use, but anything that gets fuel in there is fine. Some folks just dump a little shot of fuel right down the carb or in the plug holes. I prefer the spray bottle method because you can keep spraying fuel as it runs.
If you still suspect a fuel issue, then check your fuel pump by removing the fuel line to the carb and see if gas pumps when you pull the rope.
You did get the carb extra clean, right? Removed the high speed orifice and everything? If its blocked you will never get it going.
__________________
Wayne
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1955 EVINRUDE 15HP TURNS OVER HARD Bruce N Johnson & Evinrude Outboards 6 April 10th, 2006 04:14 AM
Now this car turns my crank! LubeDude Non-Boating Technical Topics 9 February 6th, 2005 02:26 AM
Some Help? 1983 Evinrude 15hp silenscurator Johnson & Evinrude Outboards 7 January 31st, 2005 12:40 PM
Engine turns over slowly & will not crank financeman Force & Chrysler Outboards 2 August 17th, 2003 08:00 PM
Engine turns over slowly & will not crank financeman Non-Repair Outboard Discussions 1 August 17th, 2003 06:53 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
