copelandcf
- Aug 26, 2008
- 28
I have a 1988 chris craft cavalier with a 3L 4cyl merc engine. I recently rebuilt the carb, which didnt work at first, and after finding an upside down manifold gasket I flipped it over and with a lot of pumping it started. I checked timing which was between 8-10* because the engine was surging a little at idle, and it was idling high. Keep in mind these are the initial startup settings, and it ran fine for 10 min before I shut it down.
My problem now is about an hour after startup, I tried to restart it and no go. When I pump there is still gas going into the carb. But I tried pouring a little gas in the carb anyway, and it starts. It will run for about 15-30 seconds before it dies again. Any clue what is going on now? I'm guessing some kind of fuel delivery issue. I checked the spark after carb rebuild to make sure I was getting it and it was fine, nice 1/4" jump. Could this be the accelerator pump of fuel pump? Even the fuel filters? I'm gonna check the filters now, just wanted some expert opinions before the day is over. There is plenty of fuel in the tank btw, that was the first thing I checked.
Thanks for any help!
