  #1
Old May 8th, 2009, 01:09 AM
Mister Dave's Avatar
Mister Dave Mister Dave is offline
Default Aluminum Boat with Transom Issue
The aluminum boat I am restoring has corrosion where the wood was touching the aluminum on the transom. There is even one spot where the corrosion went all the way through. What is the best solution to this problem? Is there something that I need to do to prevent corrosion from continuing? How do I fix it?
  #2
Old May 8th, 2009, 02:08 AM
film495 film495 is offline
Default Re: Aluminum Boat with Transom Issue
through the wood or the aluminum? how big is the boat? what is the max hp for the transom?
  #3
Old May 8th, 2009, 03:00 AM
Old Gamefisher Old Gamefisher is offline
If the wood was pressure-treated, the arsenic salt in the wood could have corroded the aluminum. Or, if the wood was simply holding salt water against the aluminum, same effect, especially if a different metal was in contact nearby.
  #4
Old May 8th, 2009, 03:01 AM
Robert D Robert D is offline
I'll bet the wood was pressure treated, or one of the other treated types sold for outdor use. (CCA, etc.) Many of these are highly corrosive to aluminum. Better get some quotes on getting the aluminum welded up properly. Then do the wood yourself, using exterior plywood. I'm assuming it's bolted to the aluminum...(Post some pics)....I'm thinking exterior plywood, soaked in epoxy, then wrapped in fiberglass. If you have a bolted in scenario, you could do 2 or 3 sheets of ply on some sawhorses, bond/clamp them together, and then wrap the whole thing in fiberglass. Follow up with a grinder/orbital sander to touch up, drill the holes, let more epoxy be soaked in....and put the thing on there with 3M 5200 sealing the bolts.
Just my thoughts....I'm sure you'll get several idea's here!
  #5
Old May 8th, 2009, 07:28 AM
Silver Heels Silver Heels is offline
Im redoing my boat with the same issues as your boat. It was pressure treated wood causing the corrosion, only I had a lot more than just one hole. Take a wire wheel on a drill and bust through all the powder down to clean metal. Get the large JB Weld "Industro-Weld" and skim coat over all the pitting. Back up the hole with duct tape or something on the outside. I used a pneumatic sander to level it out with the undamaged aluminum. This is definately not the only way to fix this problem, but it seemed to work well for me.
  #6
Old May 8th, 2009, 10:09 AM
The holes are through the aluminum. The JB industroweld sounds easy and quick what are peoples thoughts on this.
  #7
Old May 8th, 2009, 12:17 PM
Depends on a few factors. Is this a stress critical area? Do you want it fixed properly and safely? What's the boat worth? An old boat, up on the gunwale I might consider JB weld. But on a transom, or anywhere near the transom/hull joint....no way. I'd clean it up, and at a minimum have it welded up properly. There's many welding shops that can do this for you. I'd definitely take it around to a few and get estimates.
  #8
Old May 8th, 2009, 01:02 PM
Bob_VT's Avatar
Bob_VT Bob_VT is online now
Pictures! Take pictures.
You can weld or laminate a sheet of aluminum to the inside and then install the new sealed transom wood. It is a common problem that has been solved before. Don't Panic.
__________________
"When you see yourself doing something badly and nobody’s bothering to tell you anymore, that’s a very bad place to be. Your critics are your ones telling you they still love you and care." Randy Pausch 1960-2008 The Last Lecture
SpinnerBait_Nut's Member Map Link Please add yourself http://www.frappr.com/iboats
  #9
Old May 9th, 2009, 07:53 PM
A couple things about welding. ALL the corrosion must be removed with a Stainless wire brush, or something that won't leave behind impurities like a grinding wheel will. By the time you get through the corrosion, you will have opened up the hole even more, and probably formed a few new ones as you clean out the pits. This will leave very little material to weld to. Plus, I might be concerned about cracking at the weld. The way I see it, unless the transom is so far gone that the metal is in danger of breaking apart, what you are repairing are holes, similar to repairing screw holes. The wood is what supplies the strength. If you want to go through the hassle and expense of getting it welded, by all means go for it. As for me, once its sanded and painted, a JB Weld/epoxy repair is unnoticeable, quicker, cheaper and better
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Replacing the transom on an Aluminum boat yam350yfm Boat Topics and Questions (not engine topics) 5 March 10th, 2009 12:17 PM
outside transom board on aluminum boat garye5007 Boat Topics and Questions (not engine topics) 1 June 1st, 2008 10:11 PM
Replace my transom in aluminum boat? Bob Bismal Boat Topics and Questions (not engine topics) 11 March 22nd, 2006 02:00 PM
Aluminum boat transom replacement San Antonio Cop Boat Restoration and Building 2 December 8th, 2005 05:53 AM
Aluminum Boat Transom Rebuild cclaeys Boat Restoration and Building 4 August 17th, 2004 08:19 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
