Sorry in advance as this is my first post. I just bought my first boat and it came with one small issue. It needed a new trim pump. So having worked on cars I figured it was something that was within my skill set. So what I need to know is this. What is the absolute minimum I need to do to get that trim pump off? That is besides taking it to a local mechanic who is two to three weeks behind schedule and charging 90 bucks an hour.
I've removed the pin that holds the pump arm to the lower unit. I see another one of those big pins underneath the pump that is held in place with a small vertical pin. I've removed the vertical pin and tried to pound out the bigger pin. Only problem is that it is not budging one bit. Am I trying to remove the wrong thing? Can anyone give me some pointers? If so I would be very appreciative.
Thanks
Dan
Thanks
Dan
