RWilson2526
Master Chief Petty Officer
- Jul 23, 2007
- 810
I have a 1986 Yamaha outboard new to me. I am running through the wiring seeing what works and what doesn't.
unlike my last boat which was an I/o which had all the gauges wired into the ignition swicth, the fuel gauge on this boat is powered from the fuse block at the helm which powers lights and other accessories...there is a momentary switch that powers the fuel gauge, push it up and it powers up, release it and it shuts off.
It all appears to be original wiring and setup to the boat.
Is this a normal setup? I guess it would prevent you from leaving your gauge powered up while not on the boat and running down the battery? Its really not a problem to me as I rarely rely on the gauge anyway and I can always check the level if I want to.
Just wondering if it was something standard or some jerry rig that somebody put in.
