  #1
Old May 6th, 2009, 08:37 PM
karlt5503 karlt5503 is offline
Default Fins or no Fins?
Wanted to see if some of the experienced wakeboarders could give me some advice. I just bought my first wakeboard and have not gotten to take it out yet. I bought a Body Glove phase 4 139cm. It came with several fins I can also instal. Ive read a little about what the fins do, helping with stability and so forth. Im just wondering if i should use them? Im hoping to pick it up pretty quickly, as I do most other things. Just didnt want to spend a lot of time putting the fins on, taking them off, trying to figure what works better plus learning to use the board on top of it.
Thanks for any help or advice.
__________________
97 Crownline
5.7 235hp
18ft
  #2
Old May 6th, 2009, 10:07 PM
blacksvt blacksvt is offline
Default Re: Fins or no Fins?
If you are a beginner rider......I would use them. Boards are all different, but 1 in the front and one in the back well help increase your stability.
  #3
Old May 6th, 2009, 10:18 PM
Yes, I am a beginner rider. The board came with about 6 fins, two large and four smaller. The board has holes to place the fins in the middle or outside. So there is 3 sets of holes on the front, and 3 sets on the rear.
__________________
97 Crownline
5.7 235hp
18ft
  #4
Old May 7th, 2009, 01:19 AM
Hogger's Avatar
Hogger Hogger is offline
The smaller fins go on the outside, and the big fins go in the middle. As you progress, you might want to try removing the big middle fins.
  #5
Old May 7th, 2009, 08:47 AM
smitty1258 smitty1258 is offline
Middle Fins-IMO keep them off and take a stab without them, see how you feel. I started with, and about a week after I started, I took them off, and it felt so much better. If I woulda started without them, I could have saved myself from drinking as much as I did.
Are the 2 outside fins small and rounded?
__________________
2009 Centurion Falcon V Air Warrior
NorthWest Ohio WakeBoarders!
www.maumeewake.com
  #6
Old May 7th, 2009, 03:34 PM
Yes, all the fins are some what rounded off. Two of them are about 2 inchs tall. The other 4 are about 1 inch. (6 total) Im not sure if I should try them in the middle or one on each side.
__________________
97 Crownline
5.7 235hp
18ft
  #7
Old May 7th, 2009, 04:21 PM
dvan1901's Avatar
dvan1901 dvan1901 is offline
I would at least put the smaller outter fins on. Most advanced boards have smallish fins molded into the board. The outter fins will give you "bite" as you carve back and forth.
  #8
Old May 8th, 2009, 11:23 AM
kyle f kyle f is offline
I ride ceter finless. My board has molded in fins near the edges that slowly pop up from the rocker line. The center fins bolt in... I have ridden my board both ways and much prefer it without the center fins.
All though it is looser, it help. Its easier to break the board free for surface tricks (180's) and its more forgiving off a landing (if you land a bit to sideways, it won't cause you to catch the leading edge in the water and faceplant). Plus, since it is looser it forces you to use better edging techniques to control the board.
Since you are brand new, I suggest you get and instructional DVD. The Book and Dentention 2012 are both good ones to use.
__________________
07 MB Sports B52 V23
2000 F250 Powerstroke Diesel with Banks Stuff and Lift
84 Bronco 302/C6... Toy
  #9
Old May 8th, 2009, 02:37 PM
sickwilly's Avatar
sickwilly sickwilly is online now
I did better starting without fins because of all the years I logged on a kneeboard that had no fins, as well as some limited trick skiing. I find I really like to be able the way I am oriented a lot when riding, and can do this much easier with no fins, with no loss of trouble tracking.
__________________
2004 Stingray 190LX, 4.3 Merc, carb, SE Sport Hydrofoil
http://drri.home.comcast.net/honda/rig_3.jpg
  #10
Old May 11th, 2009, 03:19 AM
Thanks for all the advice, I appreciate it. I didn't want to spend the first time out swapping the fins out all day plus trying to learn how to wakeboard. I'll give it a try with the samller fins on the outside at both ends, then with no fins at all. With the small and large fins and outside and middle holes I would have been swapping them out all day!
Hopefully the weather will finally be good so I can take it out for the first time.
__________________
97 Crownline
5.7 235hp
18ft
  #11
Old May 11th, 2009, 04:09 AM
cube21 cube21 is offline
my 2 cents. Im brand new to wakeboarding.
I tried a few times with a friends hyperlite that had center fins. I had a hard time controlling myself and manuvering where I wanted to go. The board I bought doesnt have any fins (except the molded ones) and I like it ALOT better. The fins keep you in a straight line and were hard for me to learn because i could only go in one direction.
I think you made the right choice starting with the outer fins. After a few times out I could take them off and see if you like it better. I know I like it without any. have fun.
  #12
Old May 11th, 2009, 03:59 PM
salty87 salty87 is offline
it's all a matter of preference. very much like training wheels. they can be helpful in the beginning but ultimately you need to go it alone. actually, you can always keep the fins in but you better learn to control those edges. face plants happen quicker than you can say the words.
  #13
Old September 3rd, 2009, 11:37 AM
jason4027's Avatar
jason4027 jason4027 is offline
I have a similar question. The wife and I are just learning to board and each got Obrien Boards. Mine is a Valhalla 143 with the Removable center fin which I am using still. My wifes is a Demented, it has the moulded in fins/ribs on the outsides but also has spots to add more fins on the outside(2 sets of holes on the front and back. It didn't come with the fins. We are wondering what the difference would be since it does not have any center holes for adding the fins.
__________________
2007 Larson 208 LXi
5.0L Volvo GL/Penta
2009 Toyota Sequoia
2007 Chev 2500 Duramax
  #14
Old September 3rd, 2009, 01:11 PM
andrewbabich andrewbabich is offline
I'd put the fins on. My hyperlight has 6 small fins and I love it. Its makes it track real well, yet its still easy to spin 180's with a little lean.
Fins in my opinion will help you get up as it will keep the board straight.
  #15
Old September 9th, 2009, 05:19 PM
momostallion momostallion is offline
i think i have the same board as you.
i just put the side fins on and left the center fins off.
i had a lot harder time with my friends board which had center fins and no side fins at all. (last years model).
  #16
Old September 16th, 2009, 12:00 AM
fourwinnsnate fourwinnsnate is offline
The middle fins are for beginners that dont have the feel for the board and how to go in a straight line, carve, etc etc. If you have never gone before i would leave all the fins on once u start to crave more spins...tricks inside the wake or start carving outside the wake and jumping u will like it better without the middle fins...more forgiving for that part of things but like other people have said on here the front edge of your board can go under the water so fast u wont even know what happened. I would never take the outer fins off most high end boards have these moulded into the board and without them it would kinda be like snowboarding on a crazy carpet..if you have snowboarded before
__________________
1998 Fourwinns Horizon 18.5 5.7 Volvo Penta
  #17
Old September 22nd, 2009, 11:28 AM
craze1cars craze1cars is offline
In my experience:
Small or removed fins = less faceplants
Larger and multiple fins = more faceplants
I have 2 boards, one with pretty large 1.5" or maybe 2" fins at each end, one with very short 3/4" fins at each end. I have found that I crash MUCH less frequently on the board with smaller fins, and it is much easier to 'save' it when you're on the edge of crashing. On the board with big fins, if I make the slightest mistake, I faceplant NOW...because there is simply no time to react and make the save. It is pretty much impossible to do anything on that one with the board even the slightest bit sideways. It absolutely MUST be pointed in the direction of travel or you're going down.
It is a bit more "slippery" with the small fins, leading to the more occasional "butt scoot" type of fall-down when the board slips out foward from underneath me, but those crashes are much more pleasant than faceplants! I find the smaller fins to be a benefit for doing just about EVERYTHING except for simply riding in a straight line.
I would encourage anyone with interchangable and/or removable fins to try different configurations. You'll find a dramatic difference, and you'll find a setup you like.
  #18
Old September 24th, 2009, 01:16 PM
PitchFork's Avatar
PitchFork PitchFork is offline
Quote:
Originally Posted by craze1cars View Post
In my experience:
I agree with craze1cars after reading this thread when it first came out I took my middle fins off and WOW what a diff. It make it a lot easier to land wake2wake jumps if you were a little out of the groove. It makes it so you can ride the board sideways and turn 180's very easy. A lot more fun without the large middle fins. ALOT LESS FACE PLANTS and more w2w jumps with 180's in the air. Fun Fun Fun just hope it does not rain this weekend again.
__________________
1994 19' Chaparral 1930SST Bowrider 5.0L 4bbl Rochester
  #19
Old September 25th, 2009, 04:26 AM
JPBMW325 JPBMW325 is offline
no fins man way better
  #20
Old September 25th, 2009, 07:03 PM
ryland43 ryland43 is offline
no fins is the way to go. i took them off my wakeboard and wakeskate and like it way better
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Fins? contractorguy Wakeboarding 8 September 10th, 2007 10:23 PM
fins makinnat Non-Repair Outboard Discussions 4 March 20th, 2006 05:21 AM
doel fins joblo33 Non-Repair Outboard Discussions 1 July 26th, 2005 12:07 AM
doel fins wallydiver1 Boat Topics and Questions (not engine topics) 8 June 7th, 2003 04:58 AM
fins TouJays Mercury & Mariner Outboards 2 May 26th, 2003 04:57 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
