Re: tilt/trim guage not working
Use a volt meter and see if there is 12 volts between the black _ and purple + on the back of the gauge if there is jump between the black and gray and the gauge should read all the way up if it don't the gauge is bad if it does check the wire to the sender by grounding is at the sender if the gauge goes to up then the sender is bad if it don't there is a bad wire or connection between the sender and the gauge.
