  #1
Old May 6th, 2009, 04:57 PM
SoTexGuero's Avatar
SoTexGuero SoTexGuero is offline
Default New boat owner
I'm open for any advise.......I just bought my friend's 1994 Bayliner Capri 2050 LS....family owned since it's birth and mostly used as a "fishing boat" in freshwater only. The engine had been swapped in 2004 for a 5.7L. This is my first boat and since it is a 1994 model, I was wondering if there is anything I should be mindful of? We took it out last weekend, it's exceptionally clean, runs extremely well and fast (I love the design of this boat). Are there any recommendations from past Capri owners?
  #2
Old May 6th, 2009, 06:20 PM
gcboat gcboat is offline
Default Re: New boat owner
There's nothing that has to be 'Capri' specific. A boat is pretty much a boat in general terms. As long as you do your scheduled maintenance, keep her clean and shiny then any problems will likely not appear.
The only thing that comes to mind is your engine swap. Couple of things pop up in my ole' brain cells. One would be the added torque and h.p. on the drive ( if the same ) and the second would be your WOT. If you don't reach that specified rpm for that motor you'll likely destroy it long before its time. Especially if you're pulling skiers and tubers where a lot of throttle is concerned.
Yes, they are very nice boats and you are right - the lines are sweet.
Most 5.7 marine units will run between 4800 - 5300 rpm's at WOT. A prop change will be in order if you aren't within those parameters.
Anyhow, enjoy the boat, be safe and get a good feel for her. That extra hp could be very deceiving at speed - especially the handling issues.
__________________
Life may not be the party we hoped for, but while we are here we might as well dance
  #3
Old May 6th, 2009, 09:27 PM
SoTexGuero's Avatar
Thanks for the info. Apparently the boat (Capri 2050 LS) came originally with a 5.0L, an unfortunate mishap in 2004, force them to replace the engine to the 5.7L. I'm led to believe the shop who replaced the engine probably advised them to upgraded the drivetrain (I'll have to check). I never got the RPMs to 4800 or WOT for that matter. The prop will be the other thing I'll need to check. Is there any easy way to check these things out?
  #4
Old May 6th, 2009, 10:56 PM
SoTexGuero's Avatar
After researching WOT and props...I believe I answered the question myself. I'll have to take the boat out and find the WOT and speed to determine if I have the right prop/pitch. The boat will be use for cruising and pulling ski/boards/tubes so will that be a factor to the most correct prop?
  #5
Old May 7th, 2009, 07:55 AM
The pitch of your wheel ( prop ) is a pretty critical issue. As boats don't have transmissions the owner needs to find one ( prop ) that will make their engine run at its recommended WOT range. Anything lower - in your case - and you will be straining the motor. Anything faster and you'll see little pieces start to fly off of it.
As a general rule of thumb for every 1 degree or inch of pitch change you will see your RPM's change by 200.
Again, verify your WOT rpm's for that motor and go from there.
We could probably get into cupped wheels, S.S. , aluminum etc. Just stick with what you have and modify your pitch.
__________________
  #6
Old May 7th, 2009, 03:09 PM
SoTexGuero's Avatar
Thumbs up Re: New boat owner
Thanks for your time and knowledge. I have alot of research. First, I need to get the boat on the water again to check out the WOT, then I'll go from there. Thanks again!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
new here, new boat owner, new project cactusprick Boat Restoration and Building 2 October 9th, 2008 07:24 PM
New Old Boat owner - what is this thing installed under my boat? RAI Boat Topics and Questions (not engine topics) 4 June 30th, 2008 08:57 PM
Need Input on New Boat Purchase... (First Time Boat Owner) TheChad Boat Topics and Questions (not engine topics) 10 June 2nd, 2005 05:22 PM
new boat owner oil looks milky boat runs but almost dead? Is this a sign the mot charriex2 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 5 August 2nd, 2004 06:13 PM
new boat owner no clue of age of boat & motor GREGH Johnson & Evinrude Outboards 15 September 8th, 2001 05:41 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
