I have a 1966 20 hp Johnson pull start motor that will not fire. Last year I had some difficulty, but pulled the carb off, got a rebuild kit, and got it running. I periodically start the motor in the garage during the off-season. A couple weeks ago, it fired, ran a few seconds, then I shut it down.
Now I pull this thing endlessly and the best I can get is a slight backfire when I use starting fluid. I have checked the fuel pump, it delivers fuel out of the hose (to the carb) on every pull. Compression is pretty good at appx 100 psi and 110 psi with me pulling on a cold engine. I have a thick blue spark from the new spark plugs. I feel it may be a spark timing issue, but have not pulled the flywheel yet. The upper plug had a large deposit on the electrode (lean mix?) after last season, but I believe that plug was of the wrong heat range.
As a side question, a fella that thought he was helping me last year jacked the lean/rich adjustment on the carb all over. It is disconnected from the knob on the outside of the motor, so it may be horribly out of whack. What do i do to get it back in range?
