This motor is a manual shift. After removing the lower unit and inspecting gears, etc. I reassembled the lower unit and was able to ?feel? all three gears. After a day of usage, I am back to were I started. I can only find forward and reverse. There is no longer the ?clunking sound? when the I put the outboard into gear. Any ideas?
Also, the lower unit is leaking oil out of the propeller shaft... I would imagine this should be an easy fix by replacing the rear o-ring???
Any advice would be greatly appreciated?
