Tore down my 1982 115HP inline 6 because there was play in the crank shaft. It actual wore away the tip of the timing pointer. It appears to be in generally good shape but I have a few questions.
1: 2;nd piston from bottom has a broken ring. The only damage I can see from this is a chip in the piston along the ring grove. first picture shows this. Should I replace the piston or will this one be OK? Do I replace just the broken ring or all 3 rings.
2: The bottom cylinder was dry but the other cylinders had oil in them. The head is dry and grey. Does this indicate any problem? Is this cylinder running lean? See pic 2
3: Both endcaps have areas where the outer bearing race is that look polished. The bearings slide in easily but are snug without noticeable play.
See pic 3.
4: I plan on replacing upper and lower bearings and the broken piston ring. Anything else I should repalce/ inspect while i'm in there. Pic 4 shows the crank assembly.
I'm a noob so any advise is appreciated
See pic 3.
